Front Seal on GB
Bruce
05-02-2002 18:04:18
I am overhauling a GB gas and decided to replace the front seal on the crankshaft as I have everything apart as this tractor has not been run in 25 years. I found out that the seal is not available from my AGCO/MM/Oliver parts dealer so I am hoping someone else has had this problem and has a solution. Thanks for any help. Bruce
Bruce
05-03-2002 19:51:12
 Re: Front Seal on GB in reply to Bruce, 05-02-2002 18:04:18
Thanks for the helps guys. I feel a little better that there are some options. Bruce.
ken
05-03-2002 16:42:01
I use a National seal number 472179. It is 1.750 x 2.750 x .0312.
Kelvin
05-03-2002 13:58:57
3 ideas:
Call Welter's Farm Supply in Verona MO. 417-498-6496
or my National Oil Seal Catalog calls for a 450186
You could get an auto parts place to cross reference that old number. If you do, double check the O.D. and I.D. before you order it.
N.A.P.A. got me a front seal for a 403 power unit engine in the mid 90's. It was still in their catalog then.
