M-5 trans problem
Mark D
12-24-1998 13:04:14
I reciently bought a 1961 M-5 that wants to stick in 2 gears. When this happens the tractor will not move . Is this a common problem with the M-5 ? If so what do I start to look for once inside the trans? Any help will be appreciated.
David
12-26-1998 16:54:03
 Re: M-5 trans problem in reply to Mark D, 12-24-1998 13:04:14
What do you mean when you say "wants to stick in 2 gears"? Does the gear shift get stuck, is the "sticking" accompanied by noise? How do you get the tractor moving again? I'm suspecting a slipping Ampli-Torc. MM transmissions are usually quite reliable. Give me some more info, I'll try to help.
