Rear axles MM 49 uts
BKG
05-14-2002 20:07:29
Going to replace gaskets and oil seals on rear axles, have removed large axle nuts from bull gear,pulled axle housing from tractor,removed large snap ring from inner bearing
but can not remove axles from housing, Can one of you fellows give me any info...thanks ps.have tried bumping axles with 10lbs. and block of wood.
Kelvin
05-15-2002 19:41:06
 Re: rear axles MM 49 uts in reply to BKG, 05-14-2002 20:07:29
If all you want is to replace the seal at this point, the seal is in a flange on the outer end of the axle housing. If the axle is loose in the bearings, remove some shims from between that plate and the axle housing.
BKG
05-16-2002 08:30:04
 Re: Re: rear axles MM 49 uts in reply to Kelvin, 05-15-2002 19:41:06
I have axle and housing on work bench,large snap and flange oil seal removed, but cannot remove the axle it self from housing??? thanks brian :-(
Jim Parisot
05-16-2002 14:52:28
 Re: Re: Re: rear axles MM 49 uts in reply to BKG, 05-16-2002 08:30:04
BKG,
Like Kelvin said, the only seals on those axles are in the cover on the end of the axle housing- an oil seal and a felt ring. No need to pull the whole thing. If you still want to get the axle out of the housing you simply have to get a little meaner with it, the only thing holding it is the outer bearing cup. Be very careful not to wreck those threads, but I think you already know that. Hope this helps.
Jim
