How much is an old Moline Plow worth?
Andrew
05-20-2002 10:43:49
I know where there is a 2-16 pull type Moline plow on steel. The plow needs a crazy wheel assembly, 2 coulters, and work on the depth adjusting levers. The depth adjusting levers have been cut off and welded back on to make them shorter. Is this plow worth getting back to useable condition? Can you put an Oliver plow crazy wheel assembly (post included) into a Moline crazy wheel assembly (where the round post goes into?) What is the market for an old 2-16 plow? Any help, suggestions, or leads would be greatly appreciated. Thanks!
Lucas Delcamp
05-21-2002 06:51:22
 Re: How much is an old Moline Plow worth? in reply to Andrew, 05-20-2002 10:43:49
The most I have ever paid for one is $100. I always wanted to try to put the crazy wheel off of a bush hog on the back of the plow. The original coulters are very hard to find in this area. I have 3 MM plows.
