Jet Star 3 ampli-torc
Chuck
05-20-2002 11:58:48
I am currently replacing the motor on a Jet Star 3, since I will have the tractor split, I would also like to rebuild the ampli-torc unit. Has anyone rebuilt a ampli-torc unit? Is it a fairly straightforward operation? I would think to make this unit work properly again, you would just need to replace the wore out plates. Can these plates be purchased at a local outfit (like a NAPA) or where will I be able to find them? Any suggestions or advice would be appreciated.
galen
05-20-2002 15:54:19
 Re: Jet Star 3 ampli-torc in reply to Chuck, 05-20-2002 11:58:48
It can get a bit more complecated than just switching clutches. Do you have a super or just a Jet 3. Different style torques. Older check rollers that lock on ramps to see about wear.check bearings etc. Without doing these checks you may be wasting your time.
