How does the GB LP MM pull
IK
05-21-2002 06:13:31
How well does a GB LP pull is the 6001 to 7000lbs class at the antique pulls. What draw bar height should I run.
Andy
05-22-2002 10:29:37
 Re: How does the GB LP MM pull in reply to IK, 05-21-2002 06:13:31
I pull a GB propane, it does very well. I do the best in heavier classes,(8500 &9500) seems like they are front end heavy and need a heavier class to hook up well. Seems like it has more power than the JD, R's and 80's but being a lighter tractor you can put wieghts where you want them. One thing that is necesary is to put a straight pipe on it; it's just too quiet with a muffler on it.
Roger Roemen
05-21-2002 18:06:36
A friend of mine has one that pulls very well. He keeps the drawbar as high as it is allowed and hangs the weight on the belly.
