504 Diesel piston
Jeremy
05-21-2002 20:09:31
Does anyone have a 0.030 over bore piston for a 504 diesel. We are overhauling the diesel G1000 and it has one bad piston.
Jeremy
Peter
06-02-2002 07:09:50
 Re: 504 Diesel piston in reply to Jeremy, 05-21-2002 20:09:31
One option to going to an over size piston is to bore the block to receive a drive in sleeve that brings you back to standard bore. If that is not an option,get in touch with a major piston manufacturor such as T.R.W. or Zolner pistons-- maybe they make oversize pistons for that engine application.Hope this helps you.
Peter
Peter
06-02-2002 07:36:57
 Re: Re: 504 Diesel piston in reply to Peter, 06-02-2002 07:09:50
I was just looking through the discussion board and came across an entry that might be of help to you.Go to H D ENGINE PARTS and look to see if that info will help. Peter
