1949 U Fan Belt
Dave
05-24-2002 05:37:50
I have 1949 "U" and need replacement fanbelt. Existing numbers appear to be: MM KE 964 E. It is the big wide belt. I also need to replace the seal in the "fan drive bearing hub" Does anyone have a number on that seal? Is there a NAPA number for either of these items. Thanx Dave
Scott with Gates number
05-26-2002 14:45:13
 Re: 1949 U Fan Belt in reply to Dave, 05-24-2002 05:37:50
I just got a Gates TR32491 Green Stripe belt for my 1956 UTS Special. I don't know for sure if it will fit the earlier serial number tractor and the closest one to me is about 15 miles and I haven't had time to go look at it. Hope this helps.
Dave
05-28-2002 04:44:48
 Re: Re: 1949 U Fan Belt in reply to Scott with Gates number, 05-26-2002 14:45:13
Scott, Thanks for the homework, I'll go to NAPA and see if they can order or cross order that belt. On the U it is that real "fat" belt, about 1" wide, 1/2" deep and about 43" round.
Thanx again,
Dave
Tom Geiger
05-26-2002 05:07:41
Hello Dave & Scott
I have a MM UT with the same problem. I need to replace the fan belt and the generator belt. I expect those belts are the same on all of the U models. If you come up with gates or any other manufacturer's number, would you please post it here or E-mail me with the info.? My unit also has a loader, with a front pump, so I will have to remove a drive shaft coupling in order to install the belts, so I want to make sure that I have it right when I do it.
Thanks Guys!
Tom
scott
05-25-2002 20:07:45
I just bought that big belt last week. It was a Gates. I'll get the number for you tomorrow. If you don't see a post, then email and remind me in case I forget. I think the belt was a regional warehouse or factory order.
Andy
05-28-2002 20:15:31
 Re: Re: 1949 U Fan Belt in reply to scott, 05-25-2002 20:07:45
The Seal should have a number on it. I replaced several seals on my GB and bought them all at NAPA.
