Air Cleaner Hose
Shawn
05-28-2002 20:28:23
Hello,
I am looking for an air cleaner hose, to go between the air cleaner and carb on a 1955 GB, agco no longer offers it and i cant find a parts store that can get on like it, it is 2 1/4 inches up top and 2 inches at the carb, why would i find one that isnt rotten, would like new, anybody have any ideas
thanks
Shawn
Jim Hlasny
05-31-2002 19:38:01
 Re: Air Cleaner Hose in reply to Shawn, 05-28-2002 20:28:23
Napa #7496, it has a 90 bend with enought to trim on both ends for the right length, 2 1/4" ID both ends. Got this for a 1956 GB gas.
Napa #7220, it is long enought to trim but the end for the air cleaner is a little sloppy. You can get adapters from Napa to neck down the hose to the right ID. Got this for a 1949 UTS gas.
Good luck,
Jim
Shawn
05-29-2002 20:33:59
Hello, thanks for all your help, but a U has to make about a 30 degree bend, problem is my G has to make a 90 degree bend, and if the hose kinks it will restrick air flow,
Also the original hoses for U's are still availible though agco, i bought a couple last year
thanks anyway
Dave
06-03-2002 20:42:29
 Re: Re: Air Cleaner Hose in reply to Shawn, 05-29-2002 20:33:59
Shawn, You wouldn't happen to have the number for that hose for the "U" do you? Remember what the cost was?
Dave
Kelvin
05-29-2002 14:50:28
For my 'U' I used a top radiator hose for a larger Ford truck. One bend is perfect, just cut off what I didn't need. I'll bet something like that would work on your G too.
Dave
05-28-2002 20:45:52
Shawn: I replace that hose on my "U" I just went to Farm and Fleet and Purchased a 11 or 12 inch ridged radiator hose, one with the spring wire inside it to prevent collapsing. You can clamp the carb side down sufficiently so there is NO vacumn leaks. I can put my hand on top of the air cleaner and kill the tractor. I'm not so sure it's better than the original, It doesn't look "PICTURE PERFECT" but works better than new.
Dave
05-28-2002 20:49:21
 Re: Re: Air Cleaner Hose in reply to Dave, 05-28-2002 20:45:52
Shawn: I replaced that hose on my "U" I just went to Farm and Fleet and Purchased a 11 or 12 inch ridged radiator hose, one with the spring wire inside it to prevent collapsing. You can clamp the carb side down sufficiently so there is NO vacumn leaks. I can put my hand on top of the air cleaner and kill the tractor. I'm not so sure it's better than the original, It doesn't look "PICTURE PERFECT" but works better than new.
