M5 deisel won`t start
Dave
12-31-1998 11:03:15
it runs with a slight miss,but will not start without ether summer or winter. what can be done to fix this.
Mike
01-07-1999 14:00:48
 Re: M5 deisel won`t start in reply to Dave, 12-31-1998 11:03:15
Have you checked the compression? A deisel has to compress the air to 400 to 500 psig to generate enough heat to cause combustion of the fuel when the injectors fire.
ROGER
03-19-1999 15:05:11
 Re: Re: M5 deisel won`t start in reply to Mike, 01-07-1999 14:00:48
WE had an M5and a Super 670,both diesel,with a similar fondness for liquid sunshine.I might suggest that you check compression because above 55 degrees F they always started.Good luck!
