Dying under load.
John Kauzlaric
06-16-2002 18:20:40
Why would my 1949 UTU sometimes die under load? After it dies it starts right up,and then maybe dies again a little later. Could it be a dirty carb? Could there be something wrong with the governor?
Kelvin
06-17-2002 18:56:30
 Re: Dying under load. in reply to John Kauzlaric, 06-16-2002 18:20:40
Don't know your complete situation but here's what I would check:
Fuel bowl strainer, This will trick you-it'll seem to flow good, but not nearly enough to feed a hard working carb. stuff in the fuel inlet in the tank, stuff in the tank,sliding around on the bottom.
all the lines to the carb,
The carb. Sometimes, just taking the plug out of the bottom will flush out whatever junk was causing the problem. Sometimes you have to take it apart. Be careful, the main nozzle sometimes freezes in there, and new ones aren't to be found.
The coil. (especially if it seems to die only if hot.)
