M5 LPG gas tank
Harold
06-18-2002 21:45:10
One of the flanges on the propane tank that the hood bolts on to broke off. Someone told me that it could be welded? Has anyone done this and if so how did you prepare the tank to do it? or would it be better to just get a different tank? Also on LPG engines do you put the head gasket on dry, or do you use some sort of gasket sealer? Thanks for any advice. Harold P.S. There was another great show at Homestead last weekend. Lots of nice tractors of both AC and MMs.and a very nice parade on both Saturday and Sunday with some excellent food available all weekend.
Mostafa El-Sherif
03-11-2003 00:55:38
 Re: M5 LPG gas tank in reply to Harold, 06-18-2002 21:45:10
Dear sir, We are in urgent need for LPG tank with a capacity of 10 tons with the following specifications: 1- Capacity 10 tons
2- Use for Mixture of Butane & Propane 3- Use to Filling a gas operated trucks
4- Required Charge and discharge gear pump with gas sensor to prevent cavitations 5- Pump size 2 inches by 1 1/2 inches 6- Needs All required fittings and valves & gauges for installation including the engineering drawings for installation
7- Base We need also all drawings & dimensions of the tank base since it will be over ground in a desert area. Please inform us about delivery time starting of the purchase order date and the price CIF Alexandria port in Egypt middle east , to the name of Apache Mediterranean Corporation LDC. Telephone: (202-5193761)
Fax: (202-5193740) or (202-5225855) Eng. Mostafa El-Sherif
Materials man & stock control
Mobile phone +2012 3985356
