Fuel flow
John Kauzlaric
07-07-2002 14:56:50
Why would my utu only burn the gas in the carb and not refill?
I have super flow to the carb.
The inlet to the carb is clean.
The needle valve is clean and not sticking.
The carb appears to be clean!
Could the float be holding the needle closed somehow? Any thoughts would be greatly appreciated. Thank You.
C. Rink
07-08-2002 09:38:51
 Re: fuel flow in reply to John Kauzlaric, 07-07-2002 14:56:50
Its a possiblity. I've had the carb float rub the sides of the bowl and keep the needle nearly closed on a UB and an Oliver 77. Its hard to hear, but you should be able to hear the float "clang" as you turn the carb over when its off the tractor.
