...Moline Horsepower
Carl C
07-07-2002 21:35:59
Hey Everyone
I have this Minneapolis-Moline UTS and I don't know how "big" it is. I have an engine model # if that will help: 4 1/4 X 5 283A4. Or if someone knows where I can go to find out. I'm Greatful for any info you all can give.
Thank You
Carl in Idaho
Andy
07-08-2002 10:34:56
 Re: ...Moline Horsepower in reply to Carl C, 07-07-2002 21:35:59
You have a later uts it is a 283 cube. the nebraska test shows 42 horse but it seems most good running U's will pull more,(I think higher fuel octane). It also depends on what heads are on it.
Carl C
07-08-2002 19:56:52
 Re: Re: ...Moline Horsepower in reply to Andy, 07-08-2002 10:34:56
Andy
I have no idea which heads I have I do know that each head has a different spark plug # and it takes two different size sockets to change them. Thanks for the info now I have a general idea.
Carl in Idaho
Andy
07-13-2002 22:35:30
 Re: Re: Re: ...Moline Horsepower in reply to Carl C, 07-08-2002 19:56:52
get the numbers off your heads, (spark plug side), and post them If You have a GE series(older heads) and a 10A42## I have a cross refrence chart. If you run different heads i can be a problem.
Carl C
07-17-2002 06:58:21
 Re: Re: Re: Re: ...Moline Horsepower in reply to Andy, 07-13-2002 22:35:30
Andy
Sorry it took so long (long story) the #'s are: GE30E and 10A4209.
Andy
07-17-2002 20:44:18
 Re: Re: Re: Re: Re: ...Moline Horsepower in reply to Carl C, 07-17-2002 06:58:21
GE30E and 4209 are the same head. Moline changed the casting number at some point the 4209 is newer.
Carl C
07-18-2002 06:27:38
 Re: Re: Re: Re: Re: Re: ...Moline Horsepower in reply to Andy, 07-17-2002 20:44:18
So I'm OK then?
Bill Becker
07-09-2002 06:22:33
I had a '49 U with different size spark plugs. One head was a GE 30E (original spec), and one was a 10A4209 (from a UB). I found out that one head had cracked and it was replaced with a newer style. This is probably what happened with yours.
Bill Becker
07-09-2002 06:22:26
Carl C
07-09-2002 07:28:08
 Re: Re: Re: Re: ...Moline Horsepower in reply to Bill Becker, 07-09-2002 06:22:26
Bill
Your probably right. I mentioned it wondering if it will effect the proformance.
