MM G
Jack
07-14-2002 05:49:50
I recently purchased a G and I can't find the any info on it. It is a 48-50 model, serial number is all but gone.But I can make out the model as G.Is the G a collector item ? Only found 3 pictures of it on the net.Yesterdays serial numbers don't include the G what's up?Anyone interested?
Jack
07-16-2002 19:02:14
 Re: MM G in reply to Jack, 07-14-2002 05:49:50
I was wondering if it is worth anything.The motor is in pretty bad shape.But the rest is good.Is there any value.I was told it had a irrigation motor on it.Is there anything to that?They told me it was a 50 model.Any imput on it would be great.I couldn't understand why G serial numbers aren't availible.Is it under a different series?
Kevin Moschenrose
07-14-2002 08:04:08
Jack, I have a model GTB 1950 give me a crack at your questions!
GTB puller
09-02-2002 20:35:34
 Re: Re: MM G in reply to Kevin Moschenrose, 07-14-2002 08:04:08
Kevin, do you pull with your GTB? I have a '49 GTB I pull with. Stripped it down to 6960#, but still getting out classed by the LA's. I have the HC heads, good compression, timing is right, carb is right, but still run out of power at the end. Don't get me wrong, it's taken 1st 3 times this year and almost always places, but want more. Any ideas?
