10A4207 Heads on 5 Star?
Brad Konrath
07-16-2002 21:37:08
Does anyone know if 10A4207 heads will fit on a 5 Star gas? They are available rebuilt and should up my compression ratio, I cannot find the 10A4213 exact replacement available anywhere. The dimensions are the same, but I'm not sure about the bolts and intake/exaust locations. I appreciate any help.
LW
07-17-2002 18:29:26
 Re: 10A4207 Heads on 5 Star? in reply to Brad Konrath, 07-16-2002 21:37:08
use 4232 heads or 4231
Jeff
07-17-2002 15:20:52
Don`t use 4207 heads unless you are going to use it for pulling only. If you use pump gas you will have the problems that Andy listed.
sd
Kevin Moschenrose
07-16-2002 23:15:04
Brad, I have three 5-Star tractors. My 5-Star parts book does list the "10A4207" heads as a option. They are for the "lp" version. They would be great for a gas too. I had to replace both heads on my diesel. They came off of a M-670. I also have other information on your 5-Star. Just e-mail me if you are interested. Kevin
Andy
07-17-2002 13:08:37
 Re: Re: 10A4207 Heads on 5 Star? in reply to Kevin Moschenrose, 07-16-2002 23:15:04
I would not put 4207's on your 5star unless it is going to be strictly a puller. The are about the highest compression non-diesel head MM made. they work well with LP. The compression will be about 9.8:1 well over 200 psi. You would have to burn aviation fuel in it to prevent pre-ignition. If you burned pump gas could hammer your rods out. you could also have problems with heads lifting.
Andy
07-17-2002 20:39:50
 Re: Re: Re: 10A4207 Heads on 5 Star? in reply to Andy, 07-17-2002 13:08:37
If you can't find 4213's or 4232's,(same compression with square ports), 4210's would be fine,(and easier to find).
Andy
07-18-2002 15:36:42
 Re: Re: Re: Re: Re: 10A4207 Heads on 5 Star? in reply to Brad Konrath, 07-17-2002 21:28:46
4210 is about 6.95:1 on a 283 engine. $350 is in the ball park for 1 head. Don't throw your old one out, there are some shops that specialize in welding and anealing cracked heads.
