ID'ing a 6 cyl. MM
lc, in or
07-19-2002 09:54:30
Could someone help narrow down the models of MM with a 6 cyl. It has no 3pt., no pto, no p/s, but has electric start, WFE, either a 5 or 6 speed, a swivel seat mount, and only a drawbar. Is said to have never been in a field. Was used all of it's working life to move grain in an elevator or something indoors. There is a covered port on the rear where I'd think the pto fits, a somewhat oval shaped cover. Ring any bells?
Harrold Rhodes
07-24-2002 19:58:06
 Re: ID'ing a 6 cyl. MM in reply to lc, in or, 07-19-2002 09:54:30
I don't think any U's were built with 6 cyl engine. I think the first 6 cyl gas engines were in the G1000. Some people say some G-6's were 6 cyl gassers but I don't think so. Sounds like somebody put the 6 in a U.
lc
07-24-2002 20:25:05
 Re: Re: ID'ing a 6 cyl. MM in reply to Harrold Rhodes, 07-24-2002 19:58:06
You guys are right, I goofed on the 6 cyl. It's a 4 thumper. Geez am I glad I borrowed it to bale with. The 9n would have killed me on the hills I did, no kidding. There was even a moment that the baler pushed me with the tires locked up.
JK
07-19-2002 10:23:03
With a swivel seat and a 6 cylinder I would expect it to be a GT or GB diesel since I don't think any other models with a 6 had a swivel seat.
You should find a model & serial number on the right side of the transmission housing.
John
lc, in or
07-19-2002 16:20:38
 Re: Re: ID'ing a 6 cyl. MM in reply to JK, 07-19-2002 10:23:03
I'll look for that number. By the way, it's a gas engine, and pretty old. Looks like the same era as the letter Farmalls. Has a u-jopint in the steering shaft as it "turns the corner" around the rear of the hood/engine area. The old guy that owns it says it'll run 10 gallons of gas a day with moderate use.
lc
07-22-2002 08:44:42
 Re: Re: Re: ID'ing a 6 cyl. MM in reply to lc, in or, 07-19-2002 16:20:38
It's a U. I borrowed it for a while to help with my chores, baling especially. Drove it the 10 miles to my field and had a bunch of trouble with the fuel line plugged at a sediment bowl mid-line. It's definitely a nasty old girl. Not much at all for a muffler, trans makes lots of noise in road gear, has auto snow tires on front and, it's pink! The baling is on a hillside so I wanted something with a lot more mass than the 9N.
