53 minnie
Ken
07-21-2002 18:50:15
When I was younger I helped a farmer who had a 53 Minnie UB. Found out since that it was sitting idle after some problems with it. It would probably been pretty serious for him not to have fixed it or maybe he just got tired of fixing it. As I remember it, it was a very good running and powerful tractor. May have been a five bottom plow we pulled. Good at the end of the field as it would turn on a dime. Not like a small utility tractor that one could make use of on my small place, but thought I might just like to fix it up for old time sake and maybe let him have it back. Wondering about the availability of parts and such. Thanks.
TIM
07-22-2002 14:02:09
 Re: 53 minnie in reply to Ken, 07-21-2002 18:50:15
I also have a 53 UB in a wide front. Most parts are available. Sheet metal can be a problem. Welter's in Missouri, Brian Breberg at Lund Equipment in Minnesota, and Elder's in Western Pennsylvania are all very good, reliable parts sources.
Good Luck
Tim Brain
El Mirage, Az
Duke Adleman
08-07-2002 08:01:20
 Re: Re: 53 minnie in reply to TIM, 07-22-2002 14:02:09
I just finished refurbishing a 1953 Model GTB - wide front end. I had extremely good luck dealing with Motec Engineering in Tipton, IN (765-963-6628). They can furnish new wiring harness', rebuild your carb, gov's,, supply new plug wires, etc...
