1355 oil leaking out exhaust port
john
08-04-2002 23:01:07
not a lot just enough to run down head. Is there a seal on the valve stem? Is it worth the bother to fix?
wilbur lewis
05-16-2005 18:52:16
 Re: 1355 oil leaking out exhaust port in reply to john, 08-04-2002 23:01:07
I have a detroit diesel 371 that I found and started to work on. When I got it started, Oil is pouring out of the exhaust pipe. The engine sounds very good even though only two of three injectors are functioning well. What is causing the oil in the exhaust?
Larry O.
08-07-2002 19:17:20
Sounds like you have an injector fouled up and your fule is not all burning. I had 2 on a G1000 Vista do that and the unburnt fule blows out and runs down the head. It looks black like drain oil. Got the injectors repaired and the problem stoped. Hope this helps. Larry
Jerry
08-13-2002 17:48:03
 Re: Re: 1355 oil leaking out exhaust port in reply to Larry O., 08-07-2002 19:17:20
I have a G that does the same thing. Its a gas model and I think that the carb. is rich.
