1965 minnapolis Moline 500 positive ground on battery
mike
08-06-2002 13:02:31
Am looking for any info as to why my battery is positive ground hook-up, everything seems to work but I'm replacing some of the older wires and wonder about the battery being positive ground. I'ld like any info that will help me understand it, I never seen it before. It's a 12 volt. Thanks
Pete-mi
08-06-2002 21:08:12
 Re: 1965 minnapolis Moline 500 positive ground on battery in reply to mike, 08-06-2002 13:02:31
In most cases if you have a generator you will have positive ground. Sometimes you find a generator set up for negative ground but not often. If you have a alternator it will be negative ground.
deadeye
08-06-2002 13:23:47
Most all of the 12 volt systems are neg. ground, but I guess they could be either way depending on how it was hooked up.
