Did any of the U's have 3 point?
Loren
08-09-2002 18:31:32
Or are they all a drawbar only type setup?
JK
08-12-2002 08:59:29
 Re: Did any of the U's have 3 point? in reply to Loren, 08-09-2002 18:31:32
Moline did make a 3 point setup for the UB's & ZB's. I know it was available as an add on kit since I have seen them still wired together in the factory bundle. I don't know if they were ever shipped from the factory installed but would assume not since they aren't shown in the parts books.
If you installed one on a U, I would think it would not be very convient since you have to mount from the rear, the brake pedals are located behind the axle & would be between the lift arms. Then there would be the problem of the seat interfereing with the top link.
JK
Kevin Moschenrose
08-14-2002 00:21:30
 Re: Re: Did any of the U's have 3 point? in reply to JK, 08-12-2002 08:59:29
jk is correct also on the UB'S the operators platform sat up higher too. Totally different set up on steering wheel as well.
Kevin Moschenrose
08-09-2002 22:02:42
No, they where not too early of a tractor for 3-point. They didn't come out until the Constellation series starting with the 445's it wasn't until around 1956 for MM to have 3-point.
Loren
08-11-2002 09:38:25
 Re: Re: Did any of the U's have 3 point? in reply to Kevin Moschenrose, 08-09-2002 22:02:42
Thanks Kevin.
