MM UTU Puller (Future)
Brian F. Willia
08-10-2002 19:09:41
I have a 1947 model UTU with a KEF engine. The engine is in need of an overhaul and my question is. Does the KEF engine have alot of potential, or should I consider purchasing a 283-4A engine from a newer U. I would like to keep this tractor on the mild side but a little more than stock.
Thank in advance,
Brian
Pete Brandel
08-12-2002 16:25:25
 Re: MM UTU Puller (Future) in reply to Brian F. Williams, 08-10-2002 19:09:41
Brian,I would definetly go with the split block motor as not only are there more parts available ,but you have your choice of compression ratios by just changing heads.By just changing to a tighter(combustion chamber)head that are available you can boost your power without changing pistons if you want to keep the cost down.The sky is the limit on how much horsepower and money you want to spend.
Trever Maas
08-11-2002 15:19:34
I would go with the newer engine. I would bet that there's a lot more parts available for it.
