Ebay
Jim
08-16-2002 04:27:01
Hey, all you Minneapolis fans out there. Go to ebay and search for item #1757582824 and tell me if that is equal to a 950 or a 1050 Moline.
Thankyou in advance.
Jim
Ryan
08-22-2002 05:09:22
 Re: ebay in reply to Jim, 08-16-2002 04:27:01
The white 1870 has the moline 451 diesel engine with the oliver hydra power with white on the sheet metal. My 1870 has rough crankcase castings which makes me think the tractor engines might have been put together with second hand or left over components. I say this also b/c mine had to be totall rebuilt before I got it and it only shows 2700 hours on the tach, so something was not quite right. I am looking for bigger rear tires/rims for mine, it has 15.5x38's which are way to small for a 96 hp tractor.
Ryan
freddy
08-16-2002 22:00:30
an 1870 white is the same as a G955 MM. the give away, right away is the u-bolt clamped axles, dual steering cylinders and no external lift cylinders for the 3 point. MM G950 had taper cone wheels, external lift cylinders and one steering clinder to name a few, not to mention the oliver cab/white cab has two doors. MM had one door on the G950
Larry O.
08-16-2002 08:48:46
It's a 950. That carried the 451 engine.
Dsl
08-17-2002 08:31:32
 Re: Re: ebay in reply to Larry O., 08-16-2002 08:48:46
Nope. G955.
