335 MM backhoe
Big Larz
08-17-2002 18:13:32
I have the opportunity to purchase a 335 MM backhoe. It resembles a 445, only without torque, 3pt., and a heavy duty widefront and the obvious backhoe attachment. It runs well, but the problem is the cylinders that run and drip constantly. My question is, are kits available for this machine or is there another source for available to "repack" these cylinders
JK
08-17-2002 21:04:23
 Re: 335 MM backhoe in reply to Big Larz, 08-17-2002 18:13:32
I have a 335 Industrial with an Ottawa loader/backhoe that I have repacked most of the cylinders on. I got the parts from a local hydraulics repair shop. They were not very expensive there and they have worked well for years. I even had a new rod made for the boom cylinder since the original one had been bent and was scarred pretty bad.
John
G. L. Grumpy
08-19-2002 00:54:57
 Re: Re: 335 MM backhoe in reply to JK, 08-17-2002 21:04:23
JK, they can make new "rods" for cylinders? I have two newer ones on my loader bent by former owner and figured to find someone to straighten. Not sure they would ever be right again after that. they are bent about 45* or so. I have a shop in my town, maybe I'll call and ask about the new rods being made, thanks!
Wendell MN
08-19-2002 20:20:55
 Re: Re: Re: 335 MM backhoe in reply to G. L. Grumpy, 08-19-2002 00:54:57
I have a small shop with a press and a turning lathe. I can make the rams if nessessary, but thanks. I'm more concerned with O-rings, snaprings and other stuff needed for the cylenders, but thanks
Big Larz
08-18-2002 05:31:15
Have you had any other problems with it. have you been able to get parts for it? Any other advise?
