39 ztu stuck Valve?
Ryan
08-22-2002 05:19:14
I have a 39 ztu and it runs like a top until it warms up and then it starts popping/missing and only running on 3 cyclinders. I remove the suspect wire and it runs the same. I checked for spark later on and it had spark and good compression. Tractor has sat for 4 years and only recently been running. Could it be that a vavle will stick when it warms up?
Ryan
Andy
08-22-2002 20:24:59
 Re: 39 ztu stuck Valve? in reply to Ryan, 08-22-2002 05:19:14
I agree with kelvin. I would check it out before you run it anymore as this is a good way to burn out a perfectly good valve.
Kelvin
08-22-2002 19:35:16
perhaps your valve clearance is too tight and one of the valves (probably exhaust) is holding open when it warms up.
Shawn
08-22-2002 18:35:25
I would say that could be a possiblity, remove the valve covers and check things out, you might not be getting oil on all the valves, i have seen that happen
good luck
Shawn
