MM Combine
bruce
08-30-2002 11:43:57
We have found a MM Combine, it has no cab and a single wheel in back offset to the left. Not sure if it runs. We need to know how much it is worth and how much it would be worth fixed up.
JK
08-30-2002 12:24:32
 Re: MM Combine in reply to bruce, 08-30-2002 11:43:57
Sounds like what you have found is a Uni Tractor with a combine mounted on it. There were two style with the single rear wheel. The earlier ones had blocks and heads simliar to a Z MM and usually did not have power steering. The later ones had over head valves similar to a 445 and usually had power steering.
How much it is worth depends largely on the condition of the tractor and also of the combine.
Somewhere between junk price and what the blocks and heads are worth.
JK
