Bleeding Power Steering on M-M Big Mo 500
Todd
09-15-2002 06:53:23
Just got finished putting a Big Mo 500 back together after a clutch job. The power steering (which was disassembled) now seems sluggish. Must have air in the line. Can anyone tell me the proper procedure to bleed the system? Available manuals I have don't address this. Thanks for any help.
Kelvin
09-16-2002 07:59:35
 Re: Bleeding Power Steering on M-M Big Mo 500 in reply to Todd, 09-15-2002 06:53:23
You didn't say what you disassembled. Did you just take the lines off? If so it should work the air out as you steer it. If you took the control valve apart, I would wonder if it was reassembled correctly. Did you happen to put anything in the lines anywhere to keep out dirt? has it been apart so long dirt daubers could have gotten in there this summer?
