MM 585 puller?
Ethan Berry
09-17-2002 11:55:52
To all MM nuts out there:
I know that lately Minneapolis Moline 800 blocks are all the rage for big power. I have used M5 and G blocks. How about the G-1355 585 diesel blocks? Will 585 blocks go on a U? How? Will heads match up like stock or 800 ones do? If anyone has tried the 4-3/4" 585 blocks or have any answers let me know. Also looking for 3-7/8" U302 diesel blocks to bore for a jet star puller engine. Rare I guess.
W. Kuhns
09-20-2002 18:28:00
 Re: MM 585 puller? in reply to Ethan Berry, 09-17-2002 11:55:52
I was going to ask today if anyone ever tried to use U302 diesel blocks and put gas heads on it. I have a Jetstar 3 I was thinking about doing tis to. Does it work? Has anyone ever experimented with this?
Dave
09-18-2002 04:10:19
The valve arrangement is different and so is the bolt pattern. at the very least you would have to make a cam
Ethan Berry
09-18-2002 04:25:50
 Re: Re: MM 585 puller? in reply to Dave, 09-18-2002 04:10:19
I guess from the sounds of what I have been hearing, the 585 is kind of a MM oddball engine. Thanks for the info. 800 blocks sound more reasonable maybe.
Ethan Berry
09-22-2002 20:16:51
 Re: Re: Re: MM 585 puller? in reply to Ethan Berry, 09-18-2002 04:25:50
The valve configuration is different I hear. I have no real clear answers, but things line up a little different I know for sure.
BARRY
09-21-2002 13:42:59
My question is will 585 blocks fit a g900 crankcase?
