BG ----MM needs transmission gears
Ossie
01-12-1999 18:12:30
I just got a 1953??? BG MM and the transmission is bad I think Reverse and 2nd are out. anyone know where I can find parts ????
bruce mcjunkin
01-20-1999 15:41:24
 Re: BG ----MM needs transmission gears in reply to Ossie, 01-12-1999 18:12:30
check the parts source section of tony turners unofficial mm page at www.minneapolis-moline.com
tony says that his friend bill williams, listed on the parts page, has about everything or could probably head you in the right direction if he doesn't.
the reason i know all this is because i just got a mm bg tractor. 1953 was the only year they were made and they made 600 of them. the serial numbers range from XXXXX000 to XXXXX600. mine is XXXXX297.
Joe Justice
04-28-1999 00:00:38
 Re: Re: BG ----MM needs transmission gears in reply to bruce mcjunkin, 01-20-1999 15:41:24
The avery model R and the MM model BF tranny is all the same and will interchange parts and are more plentiful
