Block swaping
BARRY
09-21-2002 13:56:07
What is the possibility of 585 blocks and heads fitting on g 900 crankcase? Has it been done or is possible? Help-
JK
09-21-2002 17:32:08
 Re: Block swaping in reply to BARRY, 09-21-2002 13:56:07
The 585 valves are laid out like this:
E-I-E-I- -E-I-E-I- -E-I-E-I (or opposite depending which side you look at)
The 425, 451, 504, 605 & 800 gas & diesel are laid out like this:
E-I-I-E- -E-I-I-E- -E-I-I-E
The 283, 336, 340 & 403 heads are all the same as these.
You could possibly work around the bolt differences but would still have to have a cam made to match the valve layout to swap the 585 from or to the others.
John
Andy
09-21-2002 15:22:17
I think the head bolt and lifter configuration is differnt. 336/504 blocks and heads should work.
