Order Ford 8N Parts Online
8N Carb... Need Floats! They don't float no more!
Patrick/N-Tiques/OR
06-09-2001 11:12:37
Gas was pouring out thru the air intake. I decided to rebuild the carb to see of that would help. NOT! I just tested the floats by holding the upper half of the carb with the floats attached and lowering it into a can of gas to see if the floats would rise... NOT! I also took them off and dropped them right in... they sank to the bottom without even hesitating.
So, either I am doing something wrong or my floats are bad.
Where can I get new floats? Or do I have to buy a new carb?
THANKS in Advance!
Patrick
N-Tiques
www.n-tiques.com
bj/8n/mt
06-09-2001 13:16:11
 Re: 8N Carb... Need Floats! They don't float no more! in reply to Patrick/N-Tiques/OR, 06-09-2001 11:12:37
Floats that don't aren't all that unusual. Stevens Ag parts for one has floats that do. Get a gasket set too and it probably wouldn't hurt to put a new needle and seat in there as well. Although sinking floats are a problem unto themselves I would also check to make sure the needle and seat don't bind and the gasket surfaces are true as long as I had it apart.
Your mileage may vary
Mountainman
06-09-2001 12:05:38
I'd say you need new floats. They are available almost anywhere N parts are sold like New Holland or Just 8N's
Hope this helps
Mountainman (CA)
