How Hard is it to Replace a Radiator?
SOB
06-11-2001 11:12:53
I'm not quite sure what happened to my 9n radiator, but its got a few holes in it. I need to remove it and replace it. How is this done? Do I just try and unbolt it at the bottom? DoI have to remove the grill or shroud? Help!!!
SOB
bj/8N/mt
06-12-2001 05:44:53
 Re: How Hard is it to Replace a Radiator? in reply to SOB, 06-11-2001 11:12:53
Plenty of good advice below on how to get the radiator out. Since radiators have no moving parts they aren't that hard to repair. Either take it to a good radiator shop or if you want I can share how we used to make stock car radiators that had been eaten by fans work again. In any event avoid the cheapo import replacements unless you are into fabrication since the one I saw for an 8N not only had the lower outlet in the wrong place it needed repairing itself.
Your mileage may vary
llamas
06-11-2001 16:00:16
The hood and grille have to come off. No way you can get it un-snaked from the hood without at least loosening and lifting the front end - so why not just take it off and make it easy on yourself?
The OE style mounting uses two 7/16 x 1 carriage bolts which grab keyhole slots on the bottom tank of the radiator. I've never seen these come off clean. Two new ones might be in order. There is also meant to be an insulating rubber composition pad on each bolt, between the radiator and the axle mount (Ford p/n C5NN-8125-A). Oftentimes, these pads have perished away to dust. This part does not seem to be available new, but it needs to be there. I've made these out of heavy-duty conveyor belting, 1/4 thick or better. Failing that, two chunks of tire carcase would probably make a fine substitute.
There's also an insulating pad between the filler neck and the inside of the hood (Ford p/n 2N-8032) and this, or a reasonable facsimile, is available new. Suggest you install a new one as it will prevent the radiator from chafing on the hood.
As to the fan shroud - pah! Unless originality is paramount, leave the confounded thing off. As others have noted, they are nothing but a pain in the butt to install right, and to my mind, they do precisely nothing for the cooling of the motor. Use the mounting holes in the side of the radiator to mount P-clips to secure the overflow hose, and consign the shroud to the scrap heap.
HTH
llater,
llamas
There's
llamas
06-12-2001 03:39:23
 Re: Re: Re: How Hard is it to Replace a Radiator? in reply to Old George, 06-11-2001 17:03:00
Well, live and learn. I should have known that Don would carry a small but necessary item such as this. Thanks for the information.
llater,
llamas
Greg
06-12-2001 08:53:01
 Re: Re: Re: Re: How Hard is it to Replace a Radiator? in reply to llamas, 06-12-2001 03:39:23
Our local FNH dealer also has them. FWIW
smokles
06-11-2001 12:59:00
i will have to go alone with george on the haveing it recorded if it is oe mine has an after market one on it and it just dosent fit right. good luck.
SOB
06-11-2001 13:18:52
 Re: Re: How Hard is it to Replace a Radiator? in reply to smokles, 06-11-2001 12:59:00
Thanks guys!!!!
I knew I could count on you. I'm not sure if its the original or not. Not even sure what happened to it. All I can see is bent copper and it looks like something smashed into it in a couple of places. There are like 3-5 good size holes in it. The faster I put water in the faster it runs out. Don't know if its salvageable.
Bang
06-11-2001 12:57:45
SOB,
Its not too hard, but you do have to remove the
hood (probably six bolts and the gas line). The
hood is heavy enough, plus the gas tank is
attached, so its easier to empty it. However,
this may muck up your internal filter (all the
gunk currently suspended in your tank gets to that
filter first). Get a
friend to help remove the hood and replace it when
you're done. The radiator is easy, but the
replacement I got through this site needed lots of
custom fitting (e.g., the shroud didn't fit, and
there were no holes to screw the shroud to the
radiator; it mounted differently than the original
so I had to extend the holes in the frame so the
fan wouldn't hit the radiator; it was too short,
so I had to build spacers). If you're good at
fabricating, its not to bad, but I spent three
evenings fabricating, mounting, unmounting, and
remounting the radiator. The rebuild sounds better
to me! Then, it should slip right back on. Good
luck!
Bang!
Old George
06-11-2001 11:39:03
Empty the gas tank first; makes it a little lighter. Then get a warm body to help 'cause it can be awkward, especially if you don't want to scratch the paint. The shroud is attached to the radiator and can be removed after pulling it. And of course don't forget to drain what is left in the radiator and remove the hoses. If it is original, you might want to consider repair over replacement. Hope this helps
Alan Esch
45 2N kit 183513
rob 8N11071 KS
06-11-2001 11:25:21
The I&T manual claims you have to remove the hood. I would tend to agree. I don't think you could get it out the front by just removing the grill.
Once you get the hood off, it's very easy to remove the radiator.
