OT ---Ford Loader Model 19-97
Bar-n
06-14-2001 08:52:44
This is a down pressure loader with hyd. bucket. Front mount pump and a two spool
valve.
Recently while I was moving dirt with the
loader the bucket would not stay up after
I released the handle.
Now when I pull the handle back I here aloud
squeal coming from loader and the bucket will
move slowly back and then go down after I release handle.
The lift will stay up or down with no problem.
I also tried switching hoses on valve to see
if valve might be problem?Same thing.
Any one have this happen and what did you do to
fix?
Any help would be appreciated.
Thank you
Martin (IN)
Paul8n
06-14-2001 11:28:34
 Re: OT ---Ford Loader Model 19-97 in reply to Bar-n , 06-14-2001 08:52:44
Mine will only make a noise if it is low on fluid. If you have a filter then i would replace it.
