Today I tried to troubleshoot my lift problem on my 8N. The lift drops when the clutch is depressed.I followed Zane's instructions: Pulled right inspection cover, cranked up tractor with lift under load and observed. Out of the cylinder there was more than a drip, but less than a stream of hyd. fluid. It just continually spurted a small amout of fluid. I did not observe any great movement of fluid around the back of the pump where the relief valve is located. I chickened out and did not put my finger on valve while tractor was running. (Think I'm still gunshy after losing a battle with a router rigged with a biscuit cutter) However, I did notice a lot of fluid movement around the front left hand side of the pump. When I pulled off the fill cover (by the shifter) I could see oil swirling and spurting front left. With the PTO disengaged, the swirl abated (almost disappeared) at low speed while it was quite visable at high engine rpm. The tractor has a front end loader installed so it was somewhat difficult to get a view instide of case, but I used a flashlight and mirror and am fairly confident of my above report. I also noticed that with the unit under load, but with the driveshaft to the bush hog disconnected, there was still a pronounced metallic knocking or rapping noise. The lift pulsated with the noise and the whole tractor vibrated. I had thought this noise and vibration was caused by the driveshaft and gearbox on the bush hog. The fluid was fairly clear and not discolored. BTW, I found a shiny dipstick in the bottom of the case; it had evidentaly broken off feel into the case. While feeling around, it seems like there aren't moving parts around the safety valve. If I decide to try to feel the valve while the unit is running, what (or WHERE) do I have to watch out for? I buttoned it back up while I wait for Allison to clear. Made for great rock and trout fishing on the Chesapeake today. Many thanks.
