Crank rods
Phil@Tex
06-17-2001 19:53:00
I've run in to something some of you maybe able to help me with. At the top of my crank rod where the pin goes there are two small holes, one on each side of the rod. Only one of the four rods had these holes drilled through to the inside, but I noticed that all the bushings had holes in that location. My question is are those holes suppose to be drilled through to help oil the pistion pin?
TimK
06-18-2001 10:59:18
 Re: Crank rods in reply to Phil@Tex, 06-17-2001 19:53:00
I believe those are holes for oil spash, since the pin is a floating type pin in the rod and piston. New bushings aren't drilled, probably because it would be difficult to line up the oil holes when the bushing is driven into a friction fit on the rod. Drill them out and knock the burrs off the inside so the pin fit isn't jammed. That's what I did. My $.02
