Running problems
Perry Hopkins
06-18-2001 06:20:24
I put new carb on my 8N and continue to have problems after the the tractor has been running for 45 min to an hour. It starts popping and losing power and finaly quits. I have to let it set for several hours before I can get it started again.
Any suggestions?
Dell (WA)
06-18-2001 06:59:40
 Re: Running problems in reply to Perry Hopkins, 06-18-2001 06:20:24
Perry..... ...classic case of "bad frontmount sparkies"
This has been answered many times in the "archives" at the top of this great N-Board.
There are 2 time/heat related quit running problems, and restarts after 1-2 hrs of cool-down time, associated with frontmount ignition coil N-Tractors. Quits running in 5-15 minutes, bad ignition switch. Quits running in 45-60 minutes, bad frontmount ignition coil.
Unfortunately, frontmount ignition coils are not the most "robust".
Replace your frontmount ignition coil. ..... ...Dell
bj/8N/mt
06-18-2001 06:47:16
Most carb problems turn out to be electrical and yours sounds like that from here. Without more information best guesses are coil and ignition switch. When the trouble happens check for spark at the plugs and see what you find.
Your mileage may vary
