Intalling wheel weights
rob
06-18-2001 10:15:03
Can anyone suggest a proper/safe
method for intalling one piece, circular weights that mount on the inside of NAA rear wheels.
Thanks.
Tom - Calif
06-18-2001 11:06:12
 Re: intalling wheel weights in reply to rob, 06-18-2001 10:15:03
Rob, I have the same weights on my Jubilee and they are tough and dangerous. I usually lean them up against the tractor rim and then roll them up on a wedge shaped 6"X6" block and then put a floor jack under the weight to get the proper height. Then install the bolts. I've given much thought to a better way but most inventions were too complicated to justify. Unless you remove and reinstall them regularly. I took mine off after the renovation and have never put them back on. As long as I don't load my front loader with too much weight. Ya got ta watch your toes while doing this.
Larry 8N75381
06-18-2001 12:33:00
 Re: Re: intalling wheel weights in reply to Tom - Calif, 06-18-2001 11:06:12
Tom,
Please read the thread that I have linked below. Since you have a loader you should know what is in this thread. It will help your tractor front end wear and tear, steering, etc.
Regards,
Larry
Tom-Calif
06-18-2001 16:00:51
 Re: Re: Re: intalling wheel weights in reply to Larry 8N75381, 06-18-2001 12:33:00
Larry, thanks for the thread. I almost never haul anything heavy in the loader. Horse manure, (dry)shavings, etc. Except for the one time I loaded 20 tons of sand one bucket at a time. Did the coolest reverse wheely when I hit the brakes. When I restored the Jubilee and had the bucket off, I thought someone snuck over in the middle of the night and installed power steering.
Butch
06-18-2001 10:17:43
Find someone that can spell install
Mikey
06-18-2001 11:33:00
 Re: Re: intalling wheel weights in reply to Butch, 06-18-2001 10:17:43
Butch, Butch, Butch!
Now I suppose I'm in trouble for installing a "u" instead of an "i"!
Mikey
