Two dumb questions
Rob (VA)
06-20-2001 11:56:37
Two dumb questions:
1) Is the cylinder closest to the radiator the number 1 cylinder or the number 4 cylinder?
2) Also, even if you connect the spark plug wires in the incorrect order to the rotor, you will still get a spark through the spark plug wire, right?
David (ky)
06-20-2001 15:33:44
 Re: Two dumb questions in reply to Rob (VA), 06-20-2001 11:56:37
when i first bought my 9n and asked a qustion,these guys gave me good advice.....buy a manual...their worth their money
Jim.UT
06-20-2001 12:04:42
1. Cylinder #1 is closest to the radiator.
2. I believe that you will still get spark to that plug, but not at the correct moment to do any good. Firing order is 1-2-4-3 and many here have testified that mixing up 4 and 3 will result in the tractor starting but running mysteriously rough.
bj/8N/mt
06-20-2001 12:03:00
The only dumb question is the one you should have asked and didn't: e.g. is that ice thick enough to drive on
Number one is closest to the radiator
Even if the wires are crossed on the cap you will see fire at the plugs
Are you just starting a novel or is there some problem you are in pursuit of?
Your mileage may vary
Rob (VA)
06-20-2001 13:12:41
 Re: Re: Two dumb questions in reply to bj/8N/mt, 06-20-2001 12:03:00
See Martin's post. Was asking for him. That's why I said they were "dumb" questions. :^)
bj/8N/mt
06-21-2001 06:54:13
 Re: Re: Re: Two dumb questions in reply to Rob (VA), 06-20-2001 13:12:41
No offense intended
If you are helping Martin suggest he check for the fiber washer in the distributor and that the copper strip is intact
