????What model is it????
radley
06-22-2001 18:27:01
I have a 1950 8n with a tubular loader frame and front mounted hydro. pump. How do I ID this loader ?? is there a place on the framework where the manufacturer would have stamped some numbers??
Wagner? Dearborn?
Also the loader cylinders are single acting and the spool is double with float. Can I convert the cylinders to double acting? Are there pictures of Dearborn or Wagner models on the internet??
A lot of Q? ...I know but some help would be much appreciated.
Jack
06-22-2001 20:31:27
 Re: ????What model is it???? in reply to radley, 06-22-2001 18:27:01
My Wagner has an aluminum ID plate riveted on the frame above and slightly ahead of the control valves on the right. It is about 1 5/8" X 3 1/2". This is close to the pivot point of the frame/loader. Also my Wagner has double acting cylinders. Hope this helps.
Radley
07-01-2001 11:58:17
 Re: Re: ????What model is it???? in reply to Jack, 06-22-2001 20:31:27
Jack
Could you supply me with the particulars on the lift cylinders(manufacturer & dimension specs.)as well as what new plumbing/modifications is required to convert from single over to double acting lift for my Wagner?
Would be much appreciated!!!
radical.rad@verizon.net
