NAA steering box drag link connection
rick
06-23-2001 15:58:54
I had the steering box on my NAA rebuilt. After we put it back in and connected the drag links we have a bad toe out on the front tires even after shortening the links as much as they can. Any suggestions? which side should the longer link be on?
gary
06-24-2001 07:53:44
 Re: NAA steering box drag link connection in reply to rick, 06-23-2001 15:58:54
You might have to cut a section out and re-weld. I had to do that to the lift arms on my jube once. By the way....I just posted a question about my steering getting harder to turn lately, and saw your post. You mentioned that you had your steering gear box re-built. That's encouraging! Apparently the parts are available. What did it cost? Did a Ford dealer do it? Thanks...Gary
raytasch
06-23-2001 16:30:11
Long link, about 38" on the left side. Short, about 36" on right side. With the steering centered the left and right steering arms should be just about over the mounts for the radius rods. Hope this helps, ray
