Hit starter, only get whirring noise
449n
06-25-2001 07:27:47
I know this has been covered before but what is the problem if I depress starter and only get a whirring noise from starter? Does it mean the solenoid isn't working?
jimp Co
06-25-2001 07:35:09
 Re: Hit starter, only get whirring noise in reply to 449n, 06-25-2001 07:27:47
The solonoid is working, the bendix drive isn't engaging the flywheel ring.
Either the bendix is shot or the ring has come off the flywheel.
Look in the archives on removing the starter as it will have to come out to see what is wrong.
449n
06-25-2001 07:37:20
 Re: Re: Hit starter, only get whirring noise in reply to jimp Co, 06-25-2001 07:35:09
thanks for the info. I'll get starter off tonight. I had it off about 2 years ago to get rebuilt
STUMP PULLER
06-25-2001 08:33:40
 Re: Re: Re: Hit starter, only get whirring noise in reply to 449n, 06-25-2001 07:37:20
YOU ALSO MAY HAVE A PROBLEM WITH THE FLYWHEEL. THE GEARS GET WORN AND THE BENDIX CANNOT ENGAGE AND WILL JUST SPIN. WHEN YOU PULL YOUR STARTER OUT YOU WILL FIND OUT WHAT THE PROBLEM IS. YOU MIGHT TRY TURNING YOUR ENGINE OVER SO THE BENDIX CAN TRY ENGAGING AT SOME BETTER GEAR TEETH ON THE FLYWHEEL. GOOD LUCK
Bob
06-25-2001 17:30:39
 Re: Re: Re: Re: Hit starter, only get whirring noise in reply to STUMP PULLER, 06-25-2001 08:33:40
Check your battery first! My 9-2N would only whirl when the battery was real low. A lot easier than tearing it apart.
