Oil or greese on brakes
rick
06-27-2001 10:08:25
my right brake does not work. it appears that there is oil or greese on the brake pad . where is this coming from and how do you fix it? any help would be appreciated.
thanks rick
Dell (WA)
06-27-2001 10:54:15
 Re: oil or greese on brakes in reply to rick, 06-27-2001 10:08:25
Rick..... .where do you think the oil on your brakes could possibly come from? From the differential and then out the hollow axle trumpets? That is correct.
You might want to check the "archives" about this problem, as it has been asked and answered many times.
Why does it get there? Your axle seals are worn and are not longer effective. The procedure to replace your axle seals also affects the axle bearing clearances which are adjusted by shims. The procedure to adjust the axle shims is too long to post on the N-Board.
Recommend you get an I&T FO-4 manual, has all the necessary procedures with pictures. Readily available at sponsors of this fine N-Board, many tractor parts emporiums, www.n-news.com, even Ford/New Holland fer peets stakes. $25 cheep, gettcha one!..... ..Dell
