Wheels turn, tractor won't
roger
06-27-2001 18:06:04
Anybody ever have this happen? tractor wheels turn easily and correctly, but tractor just pushes on straight ahead. the front tires actually push dirt straight ahead but tractor won't turn left or right.this is with no implement attached. front end does not come off the ground.thanks in advance for any ideas
fieldman12
06-28-2001 00:21:37
 Re: wheels turn, tractor won't in reply to roger, 06-27-2001 18:06:04
I don’t know what kind of tractor you got but does it have a differential lock. If so it could be engaged and not releasing and would cause the same problem you are seeing. A differential lock will lock both rear wheels together. The lock is usually engaged by a lever on the left side if you are sitting on the seat by the footplate and it is engaged by the heel of your foot. If it is a 9n,2n,or 8n tractor it will not have a differential lock installed on the tractor.
Mike B IL
06-27-2001 20:23:23
I went throgh the same thing last year. I broke three out of the four spider gears. It was not as bad of a repair as I thought it would be. It helps to have a "friend" there to lift and balance the left axle housing. There was a lot of little pieces in the diferental housing.
ZANE
06-27-2001 20:06:11
You should take off the left axle and trumpet housing from the differential and examine the spider and side gears. One or more of them has broken or something like that has happened to the differential. It won't get any better and could cause much more damage if you continue to try to operate it this way.
A motor grader does not have a differential so that all wheels will always pull. That is the reason that the front wheels are laid down one way or the other when turning. This gives them traction enough to drag the rear wheels around.
I always wondered . . .
06-28-2001 06:31:48
 Re: Re: wheels turn, tractor won't in reply to ZANE, 06-27-2001 20:06:11
why graders front wheels laid over.....I had guessed it was to keep from sliding down hill (grin).....now I know..... thanks for enlightenment Dr. ZANE..... ..Dell
ZANE
06-27-2001 20:05:54
fast ed ohio
06-28-2001 22:09:35
 Re: Re: wheels turn, tractor won't in reply to ZANE, 06-27-2001 20:05:54
I always wondered about that, now I know. thanks.
NAA
06-27-2001 18:38:42
I suspect that the rear differential is damaged and locked up - not allowing differential action when turning
Duner Wi
06-27-2001 18:32:42
Sounds like you may have welded the rear axles together via improper axle bearing adjustment.
Jack up a rear wheel and see if you can spin the wheel by hand with transmission in neutral.
