Vane hydro pump on Jube.
Andy Mn
07-01-2001 13:34:08
The Jublie I have been looking at has a vane pump on it. I made this determination after some great input from this board. Thank you all.
This tractor is in good shape overall. I checked all the week points that you gave gave me, ie. cracked axel housings, rusted tool box etc.. BUT... it does have a vane pump.
Are these pumps more likely to go out than the piston pumps? I know they are almost impossible to fix and the conversion to a piston pump is $pendy.
How do I determine if the pump is weak or needs replacing? I think I can get a good deal on this tractor but I do not want to get in over my head.
Before I buy it, I am going to hook it to something heavy, run it up and down hills to make sure the gov. is working and run it warm, make sure everthing works then shut it off and start it again.
Any other suggestions are welcomed before I jump.
Andy MN
llamas
07-02-2001 04:44:28
 Re: Vane hydro pump on Jube. in reply to Andy Mn, 07-01-2001 13:34:08
Everything Zane said. The system has no filter, and clean fluid is the best way to extend the life of the pump as much as possible.
The Absolute Worst that could happen is that the vane pump could go TU the day after you buy it. In that case, your solution is to retrofit a later-style Vickers gear pump - there is a direct drop-in replacement. You'll also need an adapter manifold between the new pump and the old hydraulic lines. Best price anywhere on the pump is $325 from John ToTG, the manifolds are cheapest at CT at about $90, last I looked.
The vane pumps can be rebuilt but you need to find someone who knows what they're doing, and a rebuild will likely cost you a couple of hundred bucks.
HTH
llater,
llamas
ZANE
07-01-2001 19:41:54
When the vane pump is in good condition it is in my opinion better than the piston pump. The only problem is that they do wear out faster than the piston pump. The vane pump is a Vicker's pump and I think the center section that is what wears out is still available but finding it is the trick.
You need to get the tractor good and hot to see if the pump gets weak when hot. That is the tale tell thing. They will usually work OK cold but as they get hotter they get weaker is they are about shot.
