Order Ford 8N Parts Online
8n backfired then died.
OKcity8n
07-05-2001 15:08:27
My 49 with a front mount distributor has a new 12 volt coil and good fuel flow. I recently rebuilt carb, replaced wires, changed points, plugs, condensor, seals, and cap. It has been running great since February. It is around 100 degrees out today. I had been using my N for about 30 minutes to scrape the driveway. It almost sounds like the coil went bad. I tried to restart and it acted like the timing was too advanced. After it cooled, I was able to restart, but lost power and it quit in about 5 minutes. Too hot to tear the distributor down to check the points and coil so I parked it in the shed for now. After I look at the dist/coil, I will see what the archives say. Of course, comments are always welcome.
smokie
07-05-2001 15:32:56
 Re: 8n backfired then died. in reply to OKcity8n, 07-05-2001 15:08:27
sounds like the coil to me being 12 volt make shure you have the rite resistore. good luck.
smokies right . . . Dell (WA)
07-06-2001 01:17:26
 Re: Re: 8n backfired then died. in reply to smokie, 07-05-2001 15:32:56
Its your frontmount ignition coil overheated and shorting out, unfortunately, the only cure is a new one..... ..Dell
