It's been just killing me, I Have a 48 8N with a 52 engine block yet the distributor is a front mount so it has a early cam in it put in when it was rebuilt 5 years ago the engine is strong no oil use, 48 lbs oil pressure at full throttle when HOT, starts right up. But its not perfect either, the hydraulic position control needs work and I feel it could use a new cylinder and piston, and the front axel could use new bushings and the steering sector is a bit loose but works fine running around in the field brush hogging and snow plowing in the winter, 80% tires on new rims with 12.4 rears and 600 16 fronts, nice paint (but its Blue & tan) :( Overall its a good tractor that does everything you expect out of an 8N The problem is I drive it about 16 miles each way to do work at another old farm I maintain, taking a 16 foot trailer loaded with my hog, back blade, boom. chains, rake ect..... I do this 4 to 5 times a year or I should do it 5 times a year its hard to drive it both ways just to hog 6 or so acres and rake out the gopher mounds and take care of all the misc. tasks I need it for and its hard on gas because to get any speed I need it at full throttle the whole way. then to when leave it there, I need it here! The solution: a sherman high low aux tranny!!! ahh 800.00 and I'M crusing at better than 20 on less than full throttle! Plus lower gears too! I can do this, but wait.... that loose old style steering sector which is fine at 15mph is now too loose for 20-25 MPH. I'll need a late model sector..... 400.00 up to 1200.00 now and I still will need other late model parts as well to make it work. like a late model dash and sector arms ect..... ..... . Well the long and short of it is, I found another tractor, a 51 8N with a sherman installed in a tight tranny but with a worn out engine, some missing sheemetal, bad tires. The cost to rehab the 51 as a stand alone tractor is just too pricey to make it viable. BUT if I swap all the parts I need to get the 51 up to snuff from the 48..... I'm good to go and I'll make back some money from the excess parts, Transmission, Ring gears, axels the 51 engine block well... a whole tractors worth of parts. Having script fenders is not critical to my needs. Having all the good of a 51 with a sherman, dual rear seals, late sector, side mount dist. Is critical to my needs. The tough part is I need to kill my good friend the 48 to do it. And that makes me just sick inside. Rich8N
