8N
hard steering to left
RB (VA)
07-06-2001 11:27:47
From what I've found in the archives, the top bearing in my steering column, '51 8N, is failing, causing hard turning to the left.
What I can't determine from the F-04 service manual is whether I can remove and replace that top bearing without removing the steering column itself. Anyone done this?
RB (VA)
07-07-2001 07:01:15
 Re: 8N - hard steering to left in reply to RB (VA), 07-06-2001 11:27:47
Thanks, fellas, your speedy responses are amazing. I think in can do the replacement now with the details you have provided.
Roy
Claus
07-06-2001 15:35:59
Yes, Empty tank, remove hood, remove dash, remove top of column, (four bolts) r& r the bearing.
Happy Motoring
Claus
Ed Gooding (VA)
07-06-2001 12:34:38
Hi Neighbor! My response to another forum member may help you, too. Check it out by clicking here.
Regards..... ..... ..... Ed
'52 8N475798
