Order Ford 8N Parts Online
Governor on 8N 6 cyl. Funk conversion
Old Sneelock
07-07-2001 20:05:36
The governor is acting erratically on my 195? 8N. It is a 6 cyl conversion by Funk with a Ford 6 cyl 226 ci 90 hp car truck engine. I am trying to identify the governor so I can find a replacement/repair parts. The governor is belt driven and mounts on the right hand side. There is a tag on the top of the governor, but it only has a line of numbers and a too faint to read series of lower case letters? along the bottom of the tag. Any help would be greatly appreciated. I don't have a way to send pictures or I would post one.
Big Mike
07-07-2001 21:14:55
 Re: Governor on 8N 6 cyl. Funk conversion in reply to Old Sneelock, 07-07-2001 20:05:36
They used Industrial motors in the conversion that were more than likely equipped with a Ford made governor when new. I dont know what one looks like but I am putting a V-8 60hp into a N Ford and have been keeping my eye out for any type of belt drive governor that might work. Caterpillar used one on the pony engines but I would like to find one thats Ford to match. There is a guy that comes here often named Dumb Logger pretty shure he has one of these Funk 6cyl conversions maybe he can be of some help to you
John Smith
07-07-2001 21:14:35
Unless someone has changed the governor with something else, the Funk conversion originally used the standard 8N governor bolted to a Funk adapter mounting plate. The gear was pressed off and a pulley pressed on to the shaft. You should be able to use regular 8N governor repair parts.
