Sorry to hear about your accident, but glad you walked away from it. I have only a year of 2N ownership under my belt, but here are my observations of your situation and some reminders for those reading this message. Since the radius arm was broken, I would think some damage would have been done to the King Pin. What happened to the other radius arm? It is possibl that the shock loosened up one of the adjustable portions of the front axle. Taking off the hood to at least have a look at it would be a good idea. Remember, a bent radius arm or loose king pin can cause damage to the distributor cap so while it si visible, see if the clearances are okay. Also, ZANE has warned us about how many times in his professional career he had to replace a second gear damaged by bush hogging. Since the rotary mowers are not belt driven, they put greater stress on the Transmission. Next time do it in first. Since the tractor didn't turn, I would assume that the differential locked up. I am not sure if this is the case, or not, but I believe this will always happen when the PTO is driving the transmission and not the engine. Jack up the rear of the tractor and see if you can get the rear wheels to spin in different directions by hand at the same time. stay safe!
