Fellas,I have this strange problem with my 8N. It seems that nearly everytime I "go hoggin" at least once during my 2-5 hour escapades the tractor starts "losing power, groaning & attempting to stall" - (it finally does stall) Each time I stop pull over and clean out the fuel line where it attaches to the carb. (I do this by first closing the fuel line and then corking it with my finger and then restarting the flow and letting the backdraft forcibly flood back into the sediment bowl and screen. This works everytime or perhaps there is something else I am really accomplishing and this is just a catalyst for that event. I have cleaned the sediment bowl and screen at the beginning of this season. WAs easy to take apart but was kinda H@LL to get the seal back on the bowl - kept trying to leak from the top. Is there a replacement gasket for these things? Bottomline is that my 8N was always well taken care of. The fuel tank has no rust at all around the cap on the inside but something is clogging the works. The fuel flow is always strong and unimpeded (even when I flush fuel back) so that has me thinking that maybe I have a carb/jet problem. I have also noticed that I seem to have less power (seems to take a while for the engine/gov to produce enough power to get the whole hoggin assembly moving - once it is going fine, but seems a little sluggish. Compression is still ok at 115 across all cylinders. Related? Let me know what I should be checking. Radiator and shroud are in perfect shape and radiator flow is great. Hmmmmm mm. However this stalling happens nearly ever time I use the tractor for extended cutting. Thanks for any input. Andy
